The washing machine is filling and then stopping.
When I fill my washer with clothes and then start it it fills but does not run. I tried to move it to rinse but it does not. Any help?
Questa è una buona domanda?
If your washing machine is not starting or running when you fill it with clothes and try to start a cycle, there are a few potential causes to consider. Here are some steps you can take to troubleshoot the issue:
Overall, the key is to systematically troubleshoot the issue by checking for common causes and working through each step until you find a solution
We have had a Sears Kenmore washer for about 4 years now. We have had professional Sears technicians attempting to solve a lid locking problem since we owned it. NOBODY fixed it---not even with a new motherboard! NOTE that the lid switch was actually recalled. STILL, lid locking is intermittent - but still a problem. ( I Know- your automatic fill is YOUR problem. Our "workaround fix" was to put the AC power plug onto a power strip AC supply having a on/off switch. When the lid locks, and will not allow access to the wet clothes after cycle is finished, we simply turn off the power, then back on. This reboots the system, and after counting 8 seconds- the lid lock releases with a big "Click". The fill water is controlled by a "Level Sensor". Try rebooting and see if the problem persists. Likely a bad level sensor, or lid sensor.--however- Kenmore refused to post my concerns- yet the net is FULL of lid lock concerns. I'll bet the filler sensor is bad on yours. Best of luck. We just re-boot!
Ultime 24 Ore: 9
Ultimi 7 Giorni: 77
Ultimi 30 Giorni: 304
Tutti i Tempi: 4,207
Hi,
What is the model number of the washer?
da jayeff
Sounds like a drain filter problem
da Ben Capehart
