Salta al contenuto principale
Il Nintendo DS Lite è stato rilasciato nel 2006 come successore del Nintendo DS. Accedere ai componenti interni di questo dispositivo è semplice, facilitando le riparazioni.
Won't read cards.
I can/have done a hard reset and reset my parameters but it will not read that there are any cards installed. I have tried all of the cards I have. It has a new battery and is charged.
Questa è una buona domanda?
Punteggio 0
3 Commenti
I did all of that but it still won't read the cards.
da
@Jack Johnstone so opening it up and checking the card reader connector has been fitted properly did not resolve this? What exactly have you checked? take some good pictures of both sides of the board with your question. We might find something that may have been overlooked. Aggiungere immagini ad una domanda
da
This was kinda a dumb problem on my end. I figured out the DS does not register new game card in system unless you have it already in system before you turn it on. Putting this here just in case someone else has this issue.
da
Aggiungi un commento
1 Risposta
Soluzione prescelta
Did you replace the battery? Open it up and check the card reader connector has been fitted properly.
Punteggio 2
1 Commento:
I have checked and cleaned the contacts as much as possible. It just won't recognise that there are cards inserted.
da
Aggiungi la tua risposta
Jack Johnstone sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 2
Ultimi 7 giorni: 13
Ultimi 30 giorni: 47
Tutti i Tempi: 640
