Headset not powering on
Hi
I have tried to use my headset with the usb plugged in to charge whilst in use steel series arctic 9x it worked for a few minutes then went off and I’ve not been able to power them up since
Questa è una buona domanda?
Hi
First, try changing the cable or testing it with another device to ensure it works. If not there is a pinhole under the ear cushion (non-mic side) that has a reset button. Use a paperclip to press down into it to reset the 9X. You should feel a circular bump which is the button. If this doesn't fix it, download the SteelSeries Engine from https://steelseries.com/engine to a desktop/laptop and update the headphones.
Had the same issue. It stoppped functionning a couple of months after buying it. Managed to get a new headset through warranty but 3 years later it did it again. Faulty model I presume
Ultime 24 ore: 0
Ultimi 7 giorni: 10
Ultimi 30 giorni: 45
Tutti i Tempi: 5,142
