Salta al contenuto principale
Informazioni di riparazione per lo Xiaomi Redmi Note 8T, uno smartphone rilasciato nel novembre 2019. Il numero di modello di questo telefono è M1908C3XG.
After changing display, there are problems
Well I successfully changed display to some from Chinese market one, but after changing display there are some problems now:
  1. Sometimes you have to press power button multiple times to wake up display
  2. Sometimes when someone is calling you, display won't react to touches and you can not pickup call.
What could be causing this?
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Risposta più utile
@playandwin from what you are describing, it sounds like a bad display/touch screen assembly. Of course, always double check your work ensuring all the cables are properly seated and the connectors are in good condition. Also try a reset so to rule out any software issue. If you ruled all that out, you know its the display assembly. Can’t repair that but would need another replacement.
Punteggio 1
2 Commenti:
Clean the motherboard with alcohol 90 degree
da
If you put a protection on the screen put it off
da
Aggiungi la tua risposta
Lubik sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 1
Ultimi 7 giorni: 7
Ultimi 30 giorni: 20
Tutti i Tempi: 613
