Salta al contenuto principale
Guide di riparazione e informazioni sullo smontaggio dello smartphone pieghevole Android Samsung Galaxy Z Flip3, uscito nell'agosto del 2021.
How can I retrieve data
the screen wont work on samsung z flip , most of the screen is blacked out but i can still see some parts of my wallpaper like the top and bottom corner of the screen. anyway theres a lock code (swipe) and i am unable to unlock the phone. is there any way i can retrieve data from that phone or is there anyway to remotely remove the lock or bypass lock screen?
Thanks
Questa è una buona domanda?
Punteggio 2
2 Commenti
Is the device still under warranty?
da Condividi
i tried the warranty path but since my phone had a small scratch by the lense of the camera, they wouldnt cover it so i went the insurance way about things and got a replacement. just trying to transfer data but cant since the screen is mostly blacked out
da Condividi
Aggiungi un commento
2 Risposte
Soluzione prescelta
Log into your Google account on a computer and find the device and remove the password. Only problem is you still need to use the screen on the old phone.
Punteggio 3
In addition to @strongbow's answer to retrieving your data, it sounds like the screen is broken. To avoid buying another phone, I've attached a guide for replacing your screen here. I would also try to reach out to your warranty provider, or Samsung, to see if they can supply you with a replacement screen. Otherwise see if you can find a screen second hand.
Punteggio 0
Aggiungi la tua risposta
Terisa Hall sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 1
Ultimi 7 giorni: 6
Ultimi 30 giorni: 26
Tutti i Tempi: 1,581
