Salta al contenuto principale
Rilasciato nell'agosto del 2019, con le ultime GPU Turing di NVIDIA per workstation portatili. Il dispositivo sfoggia anche l'ultimo aggiornamento mobile di Intel della serie Coffee Lake.
Screwdriver for SSD drive
What screwdriver I should buy to screw on SSD drive?
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Soluzione prescelta
For this, you will want a PH0 screwdriver - here's iFixt's
You will also probably want some other tools - you can get a set of them here
If you want more drivers, you can get the Minnow driver set
If you want it all in one you can get the Essential Electronics Toolkit
Immagine Precision fixed blade Standard Phillips screwdriver used to take apart laptops. Engineered by iFixit.
Prodotto
Phillips #0 Screwdriver
$5.49
Immagine Our gateway kit to electronics repair, perfectly sized and priced for essential electronics repair.
Prodotto
$29.95
Immagine Assorted prying tools for all types of enclosure opening, cable unhooking, digitizer removal and more. A complete set of opening tools all in one kit, perfect for electronic repairs. For professionals and beginners alike.
Prodotto
Prying and Opening Tool Assortment
$9.95
Immagine The Minnow pocket-size polymer driver and portable precision bit set is our smallest kit ever! 16 precision bits and a 4 mm driver for repair on the go.
Prodotto
Minnow Driver Kit
$14.95
Punteggio 2
Aggiungi la tua risposta
Robert sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 0
Ultimi 7 giorni: 6
Ultimi 30 giorni: 22
Tutti i Tempi: 389
