Salta al contenuto principale
La Sony ICF-7600D è una radio portatile compatta a doppia conversione, controllata da un microprocessore e prodotta a partire dal 1983. Questo modello è la versione europea del modello ICF-2002.
How do I open the case?
My Sony Radio ICF 7600D has stopped working and I want to open it up to see what may be wrong with it. I have taken out 4 screws, but cannot get the case to open up fully. Anyone have any ideas?
Questa è una buona domanda?
Punteggio 4
3 Commenti
Thank you oldturkey03. Great advice and I have managed to get my radio working again.
da
That is perfect, great job:-) thanks for accepting my answer.
da
Thanks. I was stuck. Thanks. I was able to open and lock the "Rod" into place
da
Aggiungi un commento
1 Risposta
Soluzione prescelta
Try this."To open my ICF-7600D loosen (and remove) the two black screws on the L and R top and the two brass screws (one in each battery compartment). Then, because of a lip on the right lower side, open the backside turning it like a page from left to right.Furthermore, like with laptops a strong thumbnail is an indispensable asset for loosening latches." Once you have it open, you can get the schematic from here and a bit more of a service manual from here Hope this helps, good luck.
Punteggio 4
1 Commento:
+1 nice schematic
da
Aggiungi la tua risposta
rjnleonard sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 0
Ultimi 7 giorni: 2
Ultimi 30 giorni: 50
Tutti i Tempi: 4,126
