Salta al contenuto principale
Aiuto per la riparazione e la soluzione problemi dell'HP EliteBook 840 G2, un computer portatile da 14" prodotto da HP.
Bugging when plugin charger
Hello guys,
When I plug the charger the laptop is bugging.
I can't do anything. Everything is slow, even the START menu cant be launch.
But when I remove the charger Everything works fine. The problem is also I cant see the battery icon in taskbar and it going off without any notification of battery dischatging.
Please help
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Try to completely discharge your computer: remove the battery, hold down the power button for 10 seconds, and reinsert the battery.
If that doesn't work, run HP's power adapter troubleshooting tool at https://support.hp.com/id-en/help/diagno...
Third, try a factory data reset to remove any faulty drivers or software that could be causing the glitches.
Punteggio 0
Aggiungi la tua risposta
Gaspard Tryphon sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 0
Ultimi 7 giorni: 4
Ultimi 30 giorni: 11
Tutti i Tempi: 309
