Salta al contenuto principale
Revamped version of the iPhone 3G with faster processing speeds. Repair of this device is similar to the 3G, and requires simple screwdrivers and prying tools. Model A1303 / 8, 16 or 32 GB capacity / black or white plastic back.
Wet iPhone
I made my iPhone wet and i didn't know what to do and i used a dryer and i couldn't turn my iPhone off because screen didn't work. It looks alright apart from screen doesn't react to my finger or anything. I made it wet 5 days ago please help
Questa è una buona domanda?
Punteggio 3
Aggiungi un commento
4 Risposte
Risposta Più Utile
Simon.
If you can, shut your phone off (somehow, maybe let the battery drain?) and let it dry in a bag of rice. I would also recommend trying this next time instead of a dryer. A phone alone in a dryer obviously would get beat up, but a phone with clothes or other linens is likely to collect static that could hurt the internals. Let the phone sit for a day or two to be 100% sure that all moisture is out of it. Try turning it back on and see if the screen works. If it doesn't, you may need a new display assembly which can be purchased here. We have our manual for this procedure here and I also recommend that you read our water damage page here. Hope this helps good luck!
Punteggio 1
May I recommend a Thirsty Bag? It might be of some use.
Punteggio 0
Any questions https://handyrepairgremheim.com/contact/
Punteggio 0
As far as I know… this is the place to get answers, right?!?
Or is this an advertisement platform?
Punteggio 0
Aggiungi la tua risposta
Simon sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 3
Ultimi 7 Giorni: 8
Ultimi 30 Giorni: 29
Tutti i Tempi: 2,529
