Salta al contenuto principale
Repair guides for the 15-inch version of Microsoft's 4th-generation Surface Laptops, released on April 13, 2021.
Is the Battery Replacable?
Is the battery replaceable on the Surface Laptop 4 15"? Also do they sell replacement batteries for the laptops?
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
2 Risposte
Risposta più utile
Sonny Medrano looks like it's possible but a royal PITA. Anyhow, go through the service guide published by Microsoft Surface Laptop 3 And 4 English Service Guideand check this video as well (yes 13" model but looks like the step are very similar) and see if that is something you want to tackle. I have not yet found the right battery. Microsoft will charge you $400 for an out-of-warranty Battery Replacement service. Dang that is nice of them :-)
Punteggio 1
This is what the service manual that Microsoft published says:
And the "Illustrated Service Parts List" section make no mention of a bottom case assembly/backplate cover, where the battery would be found if it can't be separated. If a component is not listed as replaceable, then you won't be able to order it from a device reseller:
https://learn.microsoft.com/en-us/surfac...
Punteggio 0
Aggiungi la tua risposta
Sonny Medrano sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 1
Ultimi 7 giorni: 7
Ultimi 30 giorni: 30
Tutti i Tempi: 1,252
