Why is my washer not turning on?
I have a whirlpool closet depth washer & dryer in my new apartment. The dryer works but for some reason the washer won’t display any lights or turn on. When I hold the control lock for 3 secs it will lock but then when I repeat to unlock it nothing happens and everything stays the same as if it was locked. ( I have also unplugged / switched breaker to reset ) Any tips or ideas?
Questa è una buona domanda?
Punteggio
0
Is this combo washer/dryer older and out of warranty requiring technical expertise or diyer with advanced skills to read wiring diagrams or still in warranty (check receipts/owner's manual) to have Whirlpool service it? Your washer may have a fuse that's blown but requires disconnecting wall power and disassembling the control panel for access to circuitry.
da F Dryer
Hi,
What is the model number of the combo unit?
Have you checked if two breakers or fuses are used to supply power to the unit? A lot of combo units require 240V AC to operate i.e. 2 x 120V AC. Usually you can tell if the power cord plug and wall outlet have 4 pins.
da jayeff
