should I clean my fans manually or replace them?
my fans are dusty and i am wondering if i should clean them myself or just replace them entirely?
Questa è una buona domanda?
Cleaning is quite easy! Get a small soft pain brush and a can of can'ed air so you can blow out the dust & debris.
I would follow these two guides as its better if you remove them:
Carefully scrub the blades as well as the heatsink fin areas. I blow the air outward across the fins and a few short blasts on the fans. You don't want to spin them up, I often carefully wedge a toothpick to hold the blades from moving. Don't for get the give the logic board a quick wipe as well with the brush and then blow off what you've loosened up.
Guida
Difficoltà:
Moderato
45 minutes
Guida
Difficoltà:
Moderato
20 minutes - 1 hour
Thanks for the help
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 88
