Salta al contenuto principale
Informazioni su riparazione, smontaggio e soluzione problemi per lo Steam Deck con display LCD, una console videogame portatile prodotta da Valve, rilasciata il 25 febbraio 2022. Identificabile dal numero di modello 1010.
B button catching and getting stuck on shell
Has anyone come up with a solution to fix this? I thought maybe replacing the buttons might work, but the only part you can buy right now is the button membrane, which doesn't help. The only solutions i've seen currently is to either put a piece of tape in between the button and shell so the button doesn't catch, or to open up the steam deck and sand down the inside of the b button hole so it's nice and smooth. Anyone had any luck with the sanding?
Questa è una buona domanda?
Punteggio 4
Aggiungi un commento
1 Risposta
Here is the link to the teardown if that is the route you want to take: https://www.ifixit.com/News/57101/steam-...
I haven't done it on the Steam Deck but have for other devices. It is also worth a shot to make sure when putting it back together, that it is lining up properly.
-Warren-
Punteggio 0
Aggiungi la tua risposta
Conner C sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 1
Ultimi 7 giorni: 7
Ultimi 30 giorni: 30
Tutti i Tempi: 4,227
