Salta al contenuto principale
Un portatile Toshiba con display da 15,8" che esegue Windows. La riparazione è semplice, come nella maggior parte dei portatili. Richiede solo un cacciavite.
How to safely remove plugs
Immagine
Hi,
I would like to know how to safely unplug some connections underneath my keyboard. My first attempt ended in frustration as the plug would not come out of the socket. I did not want to force it , as I was afraid I would break the connection. Every video I see online shows the plug coming out with ease, but not mine. Am I doing something wrong?
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Risposta più utile
Off hand, I would try pushing down gently on the two white tabs in the indent on your photo and pulling gently.
I believe the tabs on the wire-side hook-in under the top of the socket.
Any how try doing that gently
Punteggio 2
Aggiungi la tua risposta
David Peddle sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 0
Ultimi 7 giorni: 2
Ultimi 30 giorni: 4
Tutti i Tempi: 255
