Salta al contenuto principale
Il Mac Pro Early 2009, noto anche come Mac Pro 4,1, ha introdotto l'architettura Nehalem di Intel nella linea di computer desktop professionali Apple nel marzo 2009. Il Mac Pro 5,1 utilizzava lo stesso design interno ma ha ricevuto ulteriori aggiornamenti della CPU nel 2010 e nel 2012.
Is this CPU compatible?
I know about delidding the CPUs for the 4,1 (which I have) but will the X5675 on this page work?
Here it says it will work,
But do I have to find a delidded version?
@oldturkey03
Questa è una buona domanda?
Punteggio 2
12 Commenti
@beanman56 probably be easier that to match the heatsink like this http://forum.netkas.org/index.php/topic,... but will cost you way more
da Condividi
Ughh.. could I just get a heat sink from a 2012?
da Condividi
@beanman56 probably not. To easy :-) Just shim it. Couple of washers and you'll be set.
da Condividi
so put washers on the screws so it's not putting too much pressure on the CPU (because it's made for a delidded CPU)when tightening??
da Condividi
@oldturkey03 - so put washers on the screws so it's not putting too much pressure on the CPU (because it's made for a delidded CPU)when tightening??
da Condividi
Mostra 7 altri commenti
Aggiungi un commento
1 Risposta
Soluzione prescelta
Hello @beanman56
Apologies in advance but I am not Oldturkey03
But I do know that the cpu will work in a Mac Pro 4,1 BUT ONLY IF YOU FLASH IT TO 5,1 I cannot stress this enough,in order for this to work you need to do it
As for de-liding people really like to charge a premium for delided cpus so I would order a deliding vise and to it manually
I have a 5,1 and it has the Intel Xeon X5675 so just a little more assurance for you :-)
Hopefully this answers your question
Punteggio 2
2 Commenti:
Uhh, I'm not that confident in being able to do it.
Thanks for trying.
da Condividi
No worries:-)
da Condividi
Aggiungi la tua risposta
Ben Capehart sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 0
Ultimi 7 giorni: 11
Ultimi 30 giorni: 24
Tutti i Tempi: 604
