Salta al contenuto principale
Conosciuta come E39, la quarta generazione della berlina di medie dimensioni BMW Serie 5.
Radiator Expansion Tank Fix
I have a 540i... the expansion tank spread apart, the two body pieces.
Do not get a new spare
I want to glue it... need to know what plastic it is made of and what adhesive I should use
Thank you very much
Questa è una buona domanda?
Punteggio 0
1 Commento:
Polypropylene. I suggest finding bmw forums for more info. Be aware of glues for pp but may not be good enough for use because expansion tanks are under heat and pressure.
da
Aggiungi un commento
1 Risposta
5 series and cooling issues. When these cars get old, things like hoses and apparently expansion tanks seem to go out.
I would strongly consider spending the big bucks and getting a replacement - even if it means begging at the dealer.
The problem with gluing is that you need both a good leak free seal and a strong one that can survive 200+ degree water. If you get the glue wrong, it will come apart again and you will have to clean off the glue to get a proper seal on your next attempt.
If it's a non-pressured tank, you can buy some really nice looking aftermarket/racing expansion tanks. If its pressurized.. forget it. Buy a new one.
Punteggio 0
Aggiungi la tua risposta
Alberto Taborcias sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 1
Ultimi 7 giorni: 6
Ultimi 30 giorni: 22
Tutti i Tempi: 535
