Salta al contenuto principale
Apple Watch Series 2, annunciato il 7 settembre 2016 e lanciato sul mercato il 16 settembre 2016.
Adhesive inside display cut
Immagine
Hi, unfortunately while changing the battery of my watch, I destroyed the bridge of the adhesive (with copper underneath) between the middle “island” and the right “island”. It should be connected like the left “island”. Hope someone understands and sees what I mean. Please see my photo.
Now, with the new battery, I cannot start the watch. The Apple symbol pops up for a few seconds, but nothing happens. Is this destroyed bridge the reason?
How can I repair the connection or get a spare part?
Thanks so much!
Questa è una buona domanda?
Punteggio 0
1 Commento:
Well, the battery was just ordered from ifixit. 😉
da
Aggiungi un commento
2 Risposte
The copper adhesive strip is an EMI shield it doesn't effect the running on the watch. But the lifted edge could be pressing on the battery so I would use a jewelers burnisher to carefully press the edge down.
Punteggio 0
2 Commenti:
Thanks so much for your quick answer.
What could be the reason that the watch is not starting?
The battery that I exchanged was bloated.
da
@oliver75 - Sadly, you really can only do swap out of the major parts like the display and the SIP if you are sure the battery is good.
da
Punteggio 0
Aggiungi la tua risposta
oliver sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 0
Ultimi 7 giorni: 3
Ultimi 30 giorni: 25
Tutti i Tempi: 298
