Salta al contenuto principale
Modello più piccolo, più sottile e più silenzioso della PlayStation 2 (SCPH-700xx) rilasciato da Sony nel settembre del 2004.
PS2 Slim SCPH-77004 problems
Basically, my ps2’s video out seems to work fine… but when loading up a game the video seems to stop working, all sound effects still work, just not the video, I think it might be the display that I was using, when a game loaded up it just showed a single color, flickering bar of pixels at the approximate bottom of the screen, when tinkering around to try and fix it with my dad, he pressed one of the lid closed switches with a screwdriver and all sound stopped working, I still expect it’s the display… and then he tried to clean it with isopropyl alcohol, which in turn made the disc drive stop spinning up… from time to time when trying to load discs after all this the ps2 would just freeze and the only way to get it to work again was to unlpug it from the wall and plug it back in. Anyone got any easy solutions for this or do I just have to completely replace most of my ps2’s parts?
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
i had this problem too, but with the video, I just got a brand new video and sound output cord and a new reader and disc drive, so just go to amazon or whatever online store you use and search for a replacement part and if that’s not the problem just replace the mother board, but that would be to much of a hassle so i would just get a new system if you dont want to go though that
Punteggio 0
5 Commenti:
Thanks for the suggestion, i spent way too much time on my ps2, my parents were already trying to sell it, but I want to fix it, obviously, I'll save up some money, get a new disc drive, as well, the one I had for the longest time would rarely read discs, and the video output cable, might try to also replace it, I forgot to mention in my post but my ps2 was modded with a Modbo Chip, although I doubt that it would cause any problems. I haven't done the modding myself, this ps2 was actually my cousin's but then they gave it to me when they weren't using it anymore.
da
no problem, happy to help, I hope you figure it out GOOD LUCK
da
the mobo chip really shouldn't affect it, the Modbo was an earlier chip compatible with V1-V12 consoles. Modbo 1.1 chips supported stealth mode, sleep mode, DVD9 playback, booting homebrew from CD, as well as booting homebrew from USB. so it really shouldn't do have anything to do with your video problems
da
Hello. Give your dad a hammer, he will fix it.
da
by mistake all game are deleted what i do
da
Aggiungi la tua risposta
PHO3N1X sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 3
Ultimi 7 giorni: 7
Ultimi 30 giorni: 20
Tutti i Tempi: 958
