Salta al contenuto principale
7,2 megapixel, zoom ottico 3x, schermo LCD da 2,5 pollici, rilasciata nell'agosto 2006
Camera Shows "Lens Error"
The camera powers on, and briefly shows an image on the LCD display. Then eventually it gives a "Lens Error" message.
Has anybody gotten this error before? Know how to fix it, I'm thinking that since the camera shows an image on the LCD, it may be a software rather than hardware problem.
Questa è una buona domanda?
Punteggio -1
3 Commenti
what error no. does it give?
da Condividi
pollytintop, I think it's one of those cameras that just says "Lens Error". Usual cause is sand grid and grime in the rings, a dislodged lens, or faulty lens motor. :-)
da Condividi
Any way to fix it?
da Condividi
Aggiungi un commento
1 Risposta
Soluzione prescelta
If the lens does not extend/retract properly, then you most likely have something stuck in the zoom gears. If the lens extends but you hear a high pitched buzzing noise, it is the focus motor that is the gears are out or your have debris it it. I would start by reading these tips and see what you get. Also take a quick look at this video to see what you might be up against :-) hope this helps, good luck
Punteggio 2
Aggiungi la tua risposta
Danny Arenales sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 2
Ultimi 7 giorni: 12
Ultimi 30 giorni: 35
Tutti i Tempi: 13,690
