Salta al contenuto principale
Informazioni sulla riparazione e lo smontaggio degli auricolari true wireless Galaxy Buds+ di Samsung. Annunciati e lanciati sul mercato a febbraio 2020.
Is there any HOPE?
I left my Galaxy Buds case with the earbuds inside in my pants pocket and washed them and then dried them as well. They still connect to my phone but the charging case is unresponsive after on the charger for 24 hours. Is there any HOPE???
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
2 Risposte
Risposta più utile
i would recommend disassembling the case and checking for water damage on the board and battery. if there is water damage attempt to replace the part. if not just dry it out, DO NOT USE RICE.
If that does not work you can either send it to samsung for them to investigate or you could possibly buy either a fake case from amazon linked below.. or you could buy a used case in good condition from ebay for your exact color if you want ti to resemble the original.
fake galaxy buds case
Hope this helped.
Punteggio 1
there is still moisture in the case. put it in a bag or container of instant rice for a week or 2. the rice with dry it out completely. than it should work again unless the battery in the case got damaged. you can buy these and replace it.
https://www.youtube.com/watch?v=StGaoAxv...
the numbers on the battery will help you order a new one normally $5-$10 with shipping from aliexpress.com
Punteggio 0
Aggiungi la tua risposta
Sean Taylor sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 1
Ultimi 7 giorni: 8
Ultimi 30 giorni: 35
Tutti i Tempi: 3,289
