Salta al contenuto principale
La quinta generazione di smartphone della linea Moto E Play, rilasciata a luglio 2018. Numero di modello XT1921.
Why won't the Microphone work?
My microphone on my Motorola will not work. Whenever I try to call people, they can’t here me.
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Soluzione prescelta
Hi,
Try using the phone in loudspeaker mode or insert a set of earphones with a microphone attachment to the headset connector on the phone and check if you can be heard OK when on a call.
If you can be heard then as you say there is a problem with the phone’s internal microphone when using the phone in the normal way on a call.
Use a magnifying glass and a strong light to visually inspect the voice inlet hole, located on the bottom edge of the phone to the right of the charge port, to see if it is blocked with lint etc.
If it appears to be blocked or you’re not sure, do not use a pin or metal probe to try and clear it as you may damage the microphone which is behind the hole. Try using a vacuum cleaner to try and clear it.
If still no good the phone will have to be opened and the microphone checked to find out what’s wrong. Here’s an image taken from the Ifixit Sostituzione schermo Motorola Moto E5 Play guide, showing the location of the microphone.
Immagine
(click on image to enlarge)
Punteggio 1
Aggiungi la tua risposta
Doge Productions sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 3
Ultimi 7 giorni: 4
Ultimi 30 giorni: 25
Tutti i Tempi: 752
