Salta al contenuto principale
Kinect è una periferica di gioco per Microsoft Xbox 360. Permette l'input audio e video per consentire al giocatore di diventare il controller.
Dog chewed through Kinect USB Cable - help!
My puppy chewed through the Kinect USB cable, I tried to splice the cables but it still won't work? Any ideas?
Questa è una buona domanda?
Punteggio 3
Aggiungi un commento
2 Risposte
Soluzione prescelta
The Kinect diagram shows a total of nine strands I attach a diagram with this message. The Xbox Kinect, when you purchase it on its own, will come with a USB converter cable that turns the special Kinect cable into a USB connection. The actually pairing should be:
Shield-Black=Shield; Gnd
Yellow-Black=12v
Red-Red=5v
White-White= Data-
Green-Green= Data+
Immagine
Punteggio 5
USB generally will have four 'signal wires'. Two pairs - each sends data one direction. i.e. Transmit, and Receive.
They can be thought of this way:
TX +
TX -
RX +
RX -
Each is usually shielded. These are very small things. You have to get them all connected right or it won't work.
There's also a ground which is the shield and may have its own inernal wire as well, and a +5V (5 volts DC) line. These also must be repaired.
Unless you have experience soldering and handling very fine wire, it might be as well to find an electronics tech perhaps at a TV shop and ask that person if they can splice or repiar the cable.
Punteggio 1
Aggiungi la tua risposta
Sonsy sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 0
Ultimi 7 giorni: 7
Ultimi 30 giorni: 30
Tutti i Tempi: 7,875
