Salta al contenuto principale
Modello A1993. Aggiornamento 2018 del Mac mini Apple. Le opzioni per il processore includono Intel Core i3 quad-core da 3,6 GHz, Intel Core i5 6-core da 3,0 GHz e processori Intel Core i7 6-core da 3,2 GHz.
Mac Mini 2018 No Power
Hi all, I’ve got a dead Mac Mini. I have confirmed the power supply is not the issue, outputting 12V via 7 pins which is as expected for this model. Something is wrong on the mainboard and I think I’ve identified the faulty component. Looks like an inductor? Plastic is melted on one side of it and it’s close to the power supply connection. Can someone please help me identify the component, I’ll need to source a replacement. Pics attached. It is the component labelled R10 1945.
Thanks!
Immagine
Immagine
@vogelek23 wondering if you can assist? A couple of years ago you helped me identify a couple of components on a 2014 mac mini board. Thanks!
Immagine
Questa è una buona domanda?
Punteggio 1
1 Commento
Managed to find a schematic, this is what the component is. Where to source?
da Condividi
Aggiungi un commento
1 Risposta
Risposta più utile
@Charles I'd get the datasheet from places like this and take that data from the electrical characteristics.
Then take this data and check places like Mouser.com Digikey,com, Jameco.com or any other electronic warehouse and see if they can match the original Superworld SSL0705 inductor.
Inductance L ( uH )0.105 ± 20%
Test Freq. 0.25V/1M
DCR (mOhm) 0.46
Irms (A) Max 31
Isat (A) Max 46
Schematics for a Mac Mini? Outstanding find.
Punteggio 1
3 Commenti:
Looks like this will do?
https://www.mouser.co.uk/ProductDetail/P...
btw schematic shows .00032 ohms there is a 46 and 32 variant..... 32 is the one to go for I believe.
da Condividi
@Charles yes, that looks like it should work
da Condividi
Did this ever fix it?
da Condividi
Aggiungi la tua risposta
Charles sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 1
Ultimi 7 giorni: 6
Ultimi 30 giorni: 21
Tutti i Tempi: 753
