Salta al contenuto principale
Repair information and guides for the CDMA version of the fourth generation iPhone. Model: A1349 / 8, 16, or 32 GB storage capacity
Logic Board Rubber Bumper Location?
I replaced the display assembly this weekend, but when I was attempting to reinstall the logic board (step 21 of the guide, in reverse), a small rubber bumper came loose from 'somewhere' on the board (I think).
Here's a picture of the bumper (with the broken screen as a backdrop to give you a sense of proportion). Can somebody identify where it belongs? It's seldom good when you've got parts left over!
Questa è una buona domanda?
Punteggio 3
Aggiungi un commento
4 Risposte
Soluzione Prescelta
It goes on top of the Logic Board, under the two Front Screen Flex Cables. I have seen a couple of iPhone 4 without this installed or just missing and they functioned perfectly.
Punteggio 8
2 Commenti:
That did it!
da
That was a huge help. Thanks!
da
Also, notice there is a thick and thin side to the bumper, and the thin side should be on top, or toward the back panel.
Punteggio 2
That little plastic bumper folds over the top of the logic board assembly where the Digitizer ( Front Panel) cables come up and over. If you look close at the bumper there is a small grove that is the same size as the boards thickness. Its just there to protect the Digitizer's cables from the rough surface of the logic board.
Punteggio 2
1 Commento:
Thanks for that info... Super helpful
da
what would happen if you were to put this on the wrong way
Punteggio 0
Aggiungi la tua risposta
Matt Strange sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 9
Ultimi 30 Giorni: 23
Tutti i Tempi: 7,552
