Salta al contenuto principale
Guide di riparazione e assistenza per il OnePlus 5T, uno smartphone Android con display AMOLED da 6,01". Rilasciato a novembre 2017. Successore del OnePlus 5. Numero di modello: A5010.
Replugging screen : upside-down and multiple
Hello !
I just received a new screen to replace my broken OnePlus 5T screen. I thought it would be easy game : dissemble, plug and done.
However, the result is not quite what I expected. The screen is upside-down and displays two times what should appear once (as you will see attached). Also : the touch screen is at the right place, as if nothing was different from a new phone with perfect display…
Have I done something wrong… ? Do you have any solution?
Many thanks in advance !
Immagine
Questa è una buona domanda?
Punteggio 1
Aggiungi un commento
1 Risposta
Soluzione prescelta
KasDing the only thing you want to check on is your connector. Make sure that the pins are straight and not bend sideways etc. Ultimately this sounds and looks like a bad screen. Return it to wherever you bought it from and request a new display.
Punteggio 3
2 Commenti:
Hello oldturkey03 !
As you said something could have been wrong with the pins, but surely the screen was down.
I returned it and got another which works perfectly :)
Thank you for your help !
da
KasDing glad it worked out for you! Keep on fixin'.....!!!
da
Aggiungi la tua risposta
KasDing sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 0
Ultimi 7 giorni: 2
Ultimi 30 giorni: 18
Tutti i Tempi: 487
