Yellows look more greenish on my LG TV.
This issue is kind of hard to explain but I’ll try my best.
I have a 43UN71006lb LG TV that I purchased last year. While it’s not the greatest 4K tv in the world it does the job. The only problem I’m having with it is yellows appear more “greenish yellow”The only way I can get yellows to look how they should is if I turn down the contrast but this darkens the screen too much. The issue is only really noticeable with bright yellows like the Simpson’s for example. The strange thing is if I leave a bright yellow screen on the tv for a few minutes,the tv will automatically adjust it from the greenish-yellow to the normal yellow it should be. I’ve gone through all the menus in my tv and turned off anything that auto adjusts the picture but the issue persists.
The issue is present in all picture modes. The ones I use are expert dark room or cinema for TV,and game mode for my PlayStation 5 with the issue being more noticeable in game mode with HDR enabled. If I’m playing a game, light sources like lanterns,fire, the sun at certain times of day etc will have a slight green tint to them.
Ive tried adjusting the red-green tint slider to be more red, but this doesn’t fix the issue. I’ve also tried using different picture modes like warm 1-3 with no luck either(I keep it on warm 2 anyway). I’ve fiddled with white balance a little but I guess you need proper calibration equipment for that stuff?
Ive factory reset the tv multiple times.
I’ve checked connections to external devices.
Used different HDMI ports and cables.
Does anyone have any ideas what I could do to possibly fix this issue or what could be causing it? Thanks in advance.
Questa è una buona domanda?
12 Commenti
Hello everyone, my question is as follow, I am connected to dish tv and I am watching a program and the screen turn solid yellow. I switched to the hopper and it still turns yellow. Is it my lg um6910puc or dish? How do I fix this issue?
da Ray
@rayka
If it is yellow from the start, try connecting the TV to another signal source e.g. dvd player and check what the picture looks like.
If still yellow it is the TV if not it is the hopper/dish device or connection to the device.
da jayeff
Ben, I have the same problem. It is particularly noticeable during the super bowl with the Rams uniforms. It is a yellow-green in the center of the screen and a true yellow on the edges If you don’t notice it you don’t notice it. Once you are aware it is pretty obvious
da John T Walkup
John, I also noticed there was a problem with my LG OLED (OLED55B7A-U (LG OLED 55” purchased in 2017) during the playoffs (Packers green) and Super Bowl (Rams purple), I had the same yellow-green center of the screen issue. I played this YouTube video ( https://www.youtube.com/watch?v=sW10W0Wc...) in full screen on the TV and was shocked by the amount of yellow failure. I now need a new TV, it won't be an LG!
da Vince Hibbs
I have the same issue with my LG OLED 55” TV, It was supposed to be the top model back when I purchased it and had excellent reviews across the board. It is not an issue I had noticed even the entire first year I had the tv. Then it started being very obvious, mostly with graphics such as in ads and news… not so bad when watching a movie or tv series. I have to say that I have tried every possible adjustments and nothing I will do seems to fix that issue. Tbh, even my 15 years old LCD Samsung has a much better image than that LG TV. Just the blacks are very good on the LG OLED, but the rest is not up there at all. I am super disappointed and will probably never buy LG again. I will give this one away and buy a new one instead.
da Vincent Joly
Mostra altri 7 commenti
