Hi @km21 ,
Here’s an image of the No power troubleshooting flowchart, taken from the service manual for your model TV.
(click on image to enlarge)
You will need to have a DMM (digital multimeter) and know how to use its Ohmmeter function so that you can check if all the fuses located on the P board, mentioned in the flowchart are OK or not. Do this with the AC power totally disconnected from the TV.
If you find a faulty fuse then you have to find out why it blew, because fuses don’t blow for no reason.
If all the fuses are OK then as the flowchart suggests you need to check the A board.
Initially check for any obvious signs of component damage e.g. heat stressed components or blown or bulging capacitors.
The service manual is quite good as it has the schematics for the boards which will help to find out what’s wrong.
If you don’t know how to test electronic components then you will either have to find someone who does or contact a reputable, professional TV repair service.
Votato
Annulla
Punteggio
2
Annulla
Scorri questo thread per trovare il posto appropriato per questo commento. Quindi, fai clic su "Allega commento a questo post" per spostarlo.
