Salta al contenuto principale
La Ninja Coffee Bar CF086 è una macchina per il caffè dotata di caraffa termica da 43 once (1,27 litri) e tecnologia Auto-iQ One Touch Intelligence.
locate sensor inside CF091
i need to open up Ninja and locate the sensor and bypass, even on a full carafe after 3 seconds it beeps and stops brewing
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Probably not the sensor. It is probably clogged in the upper part before the spout. I have had 3 of these machines that all did that right after about a year…I finally figured out the problem.
Punteggio 0
2 Commenti:
Hi Brent! Were you able to unclog your machine? If so, would you be able to share how? Thank you!
da
Yes, please elaborate on how to fix this. Maybe cleaning with a pipe cleaner? Nothing seems clogged, though. The water comes out just fine. It just stops after a few seconds and beeps.
da
Aggiungi la tua risposta
Sharon Dusenbery sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 0
Ultimi 7 giorni: 0
Ultimi 30 giorni: 7
Tutti i Tempi: 1,119
