Salta al contenuto principale
Il Motorola One 5G Ace è un phablet Android rilasciato il 13 gennaio 2021.
Glass replacement...what should I know before trying.
Glass face only has shattered. What should I know before deciding on trying to fix it myself or have repaired.
Such as: how hard is it to open case and then close properly? Is there adhesive holding face-plate that will be compromised and so not go back together properly? Or anything to look out for when it is open and removing broken glass?
Questa è una buona domanda?
Punteggio 7
Aggiungi un commento
2 Risposte
Risposta più utile
Too late for you but for the record: I had to get my Moto One 5G Ace screen fixed (just the glass, LCD was fine) and I took it to a repair shop. They fixed it, but apparently in the process they broke the speaker connection because of the way the adhesive was applied. Lucky for me they fixed it free because it was technically their fault, but it sounds like it might just be a matter of how the phone is constructed.
TL;DR be careful with the speaker cable when taking the phone apart to fix the screen.
Punteggio 5
2 Commenti:
how much was the charge?
da
there is no speaker cable on either of the speakers. speakers are connected by spring contacts on the speaker itself and there's no adhesive used on them.
da
Screen replacement bord
Punteggio 0
1 Commento:
Made, we don't understand what you're saying or asking. Please state your question or answer in much more detail. That way even if this is a translation issue, we will still get a good idea of what you're saying.
da
Aggiungi la tua risposta
LCuz sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 0
Ultimi 7 giorni: 1
Ultimi 30 giorni: 16
Tutti i Tempi: 4,525
