Salta al contenuto principale
Una stampante laser a colori da tavolo di dimensioni standard prodotta da Konica Minolta con una risoluzione massima di 2400,0 dpi x 600,0 dpi.
Error 2474 on status
Hello
I have replaced the toner detection sensor yet still get this error code and it states that the toner cartridges need replacing yet they are new. any help/advice would be much appreciated.
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Soluzione prescelta
Try pulling out the Ink cartridge you replaced. And shutting down the printer then putting the cartridge back in after you restart the printer.
Punteggio 3
2 Commenti:
Thanks for your offer of advice, sadly it didn't work. I still get the message that each colour toner is not installed.
da
Most of the time this happens because the contacts are not clean. Look for a copper or metal contact on the ink cartridge. And be sure they are clean you can use a Pencil eraser to clean them. Then exam where they would touch in the cartidge holder. And clean those contacts. See if that helps.
da
Aggiungi la tua risposta
albert57dean@btinternet.com sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 1
Ultimi 7 giorni: 3
Ultimi 30 giorni: 12
Tutti i Tempi: 458
