Salta al contenuto principale
La Lancer è una berlina a 4 porte o una hatchback a 5 porte prodotta da Mitsubishi. Il modello standard include motori con cilindrate da 1,5 a 2,4 litri, a benzina o diesel. Le opzioni di trasmissione includono automatica, manuale e CVT.
Performance issue with Lancer
Hi
I have noticed that when I turn on the AC, the acceleration power decreases a lot. Any idea why this happens?
Also, recently i noticed that i no longer get any Active Stability Control (ASC) display information on my information screen. I saw that warning when i was driving on a wet road but now my vehicle pulls a lot when i cut around bends.
Does anyone know why this has happened? Could it be that i need to get a sensor checked? Please advise.
No check light appears, have just recently scanned to look for error codes, no errors found.
Mileage is currently at 77k. Spark plug (NGK brand iridium single point) was changed at 54k.
Vehicle specs: Lancer 2013 GT, 4b11 engine, 2 litres. non-turbo. 2WD.
Have got the vehicle fully serviced. My engine bay setup is shown in the photo below
Immagine
Questa è una buona domanda?
Punteggio 0
1 Commento:
I noticed that the car slides a lot meaning that there is little to no traction as previously when going at high speed. Will have this checked at a garage.
da
Aggiungi un commento
1 Risposta
you won’t need to check for sensors, the A/C system doesn’t have any that will directly throw up a code just for that, if the sensor was faulty on the ASC then the light would be on the dash constantly and its would constantly be disengaged, have you noticed if the ABS or traction is faulty or are they still working okay? a garage may be able to get to the bottom of it a lot quicker
Punteggio 0
Aggiungi la tua risposta
Ravinesh sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 1
Ultimi 7 giorni: 5
Ultimi 30 giorni: 17
Tutti i Tempi: 704
