Salta al contenuto principale
This is the upgraded version to the P75-A7200, with the only difference being a pre-installed 8.1 OS from windows on the newer device, rather than 8.0.
7 Domande Visualizza tutte
How do I replace the battery plug in slot?
The laptop is old and it needs a couple of new parts in it, one of which being the square piece you plug the charger into. The piece is exposed outside of the case and I’m wondering really how to fix it.
Questa è una buona domanda?
Punteggio 1
Aggiungi un commento
1 Risposta
Soluzione Prescelta
Hi @duo01,
You need to remove the battery from the laptop and then open the laptop and remove / replace the DC-In jack cable (supplier example only to show part and cost).
Here’s the iFixit Toshiba Satellite P75-A7100 guides that may help
Punteggio 1
Aggiungi la tua risposta
duo01 sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 61
