Salta al contenuto principale
Informazioni e guide di riparazione per il leggero aggiornamento del MacBook Air di fine 2018, con lo stesso numero di modello (A1932) e numero EMC (3184). Questo modello è dotato di un display True Tone e di una batteria leggermente rivista.
Left hand speaker muffled and staticy
Okay, my MacBook Air’s left-hand speaker is weird. It very very muffled and full static when compared to the right.
I thought it could be water damage and decided to replace it. I did that myself and it all went well and then went to check and no change on that speaker. It was the same as before not even a single change or improvement.
I ran Mac diagnostics, nothing came up. I also reset NVRAM/PRAM as someone had suggestion that might help. Still nothing. I’m at a total loss of what to do.
Also, I am 100% sure when I got it first it was working fine.
Questa è una buona domanda?
Punteggio 1
Aggiungi un commento
2 Risposte
What do you hear when you plug in a good set of headphones in via the headphone jack? Use the balance control to bias which headphone is playing. Do you hear it with the headphones?
If you do then the MacBook Air 13" (Late 2018-Mid 2019) Audio Daughterboard or MacBook Air 13" (Late 2018-Early 2020) Audio Daughterboard Cable to the logic board is the issue. If its clean on both sides, then the logic board speaker cable connector has a problem.
Review this guide: Sostituzione scheda audio MacBook Air 13" Retina Display fine 2018
Immagine Replace a torn or damaged cable connecting the logic board to the audio daughterboard containing the headphone jack and connectors for one speaker and the Touch ID sensor.
Prodotto
$19.99
Immagine Replace a corroded, dirty, or damaged headphone jack by swapping in an audio daughterboard containing the headphone jack and connectors for one speaker and the Touch ID sensor.
Prodotto
$59.99
Punteggio 0
5 Commenti:
Earphones have no problem with this. Only occurs when I use the in built speaker,
da
Look at the logic board for corrosion.
da
@danj I am pretty sure there was none since I did open up when replacing the speaking thinking that was the issue, and saw nothing much there in terms of it looking diffrent.
da
I think you'll need to bring your system into someone who has the skills to diagnose your issue. There is a limit on what I can offer for help.
da
@danj Thank you. Just wanted to exhaust all options before I did that in case it's something I can fix on my own. Really appreciate you taking you time to try and help me.
da
I had the same problem with 2 Macs, the solution was to clean the grille with a dry/clean toothbrush. The issue was that the micro-holes were blocked, which can be confirmed by passing light through them.
I could diagnose the problem by connecting the speaker without installing it, I leave it carefully hanging and it sound really loud.
I attach a photo of the blocked micro-holes.
Immagine
Punteggio 0
2 Commenti:
@oliversi - To many bread crumbs! 😆
da
it acted more like a cheese grater :)
da
Aggiungi la tua risposta
SeanErik sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 0
Ultimi 7 giorni: 4
Ultimi 30 giorni: 24
Tutti i Tempi: 755
