Salta al contenuto principale
Guide di riparazione e informazioni per la soluzione problemi per il Game & Watch, una serie di 60 videogiochi portatili prodotti da Nintendo dal 1980 al 1991.
Right button moves character left
I have an OCTOPUS Game & Watch that works fine except that lately, if I press LEFT once during the game, LEFT stops working and if I press RIGHT the character moves left for about 5-10 seconds and after RIGHT moves the character right again, the problem repeats itself. I did try to do a light cleaning with rubbing alcohol and although the buttons are more responsive, the problem didn’t go away. Has anyone else experienced this or know how to fix it?
Questa è una buona domanda?
Punteggio 1
1 Commento:
Did you also give the motherboard a light clean with the alchhol?
da
Aggiungi un commento
1 Risposta
Im having a similar issue, except my left button doesnt work and the right button is spammed upon powering the g&w… i have parachute, so maybe theyre kickin the bucket after 40 years. :/
Punteggio 0
2 Commenti:
Fixed it! Mine had residue from the carbon pads on the membranes. I just scrubbed contacts with some isopropyl with a qtip as a last ditch effort after checking all the test points with a multimeter. What i thought wouldve been corrosion, really turned out to be carbon and rubber gummed up. It looked clean, but turns out it was dirty. Good luck brotha
da
IPA only on the board and button pads - NOT ON THE RIBBON CABLE.
ruined a donkey kong 2 erasing the connectivity pads of the black and white OG ribbon cable.
new ribbon cable on fleabay £20 macguy/canada - verified working replacement. gold coloured modern looking.
da
Aggiungi la tua risposta
GameNWatch sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 1
Ultimi 7 giorni: 6
Ultimi 30 giorni: 14
Tutti i Tempi: 770
