Salta al contenuto principale
L'ASUS Transformer Book Flip TP500LA è un computer portatile 2-in-1 con schermo da 15,6 pollici e display ruotabile a 360 gradi.
How to replace Touch Screen Digitizer on ASUS TP500LA?
I need to replace ASUSTP500LA LAPTOP TOUCH SCREEN, I removed the broken one, but I do not know how to connect the new one.
Update (03/24/2021)
I am so sorry, I forgot to add the images
Immagine
Immagine
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Soluzione prescelta
This web site somewhat shows how to install the new Touch Screen Digitizer:
https://www.laptopscreen.com/English/mod...
Punteggio 1
2 Commenti:
The information is not the same to the laptop I have. I removed the broken
screen, I can not put back in the frame the two connectors
da
@vmarquez079
Hi Victor,
Are you certain you have correct part? Look on the broken one for its part number and on the replacement part to see if you have the correct one.
Installing should just be the reverse of taking out th broken part.
The web page I sent you should give you some hints on what to do.
Did you click on the info tabs for more details?
da
Aggiungi la tua risposta
Victor Marquez sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 0
Ultimi 7 giorni: 3
Ultimi 30 giorni: 28
Tutti i Tempi: 315
