Salta al contenuto principale
Telefono di un marchio cinese, esegue AndroidOne, viti frontali Pentalobe
New LCD no brightness
I changed the LCD of the phone, using a 3rd part LCD, everything works fine until it turns on. Once it starts to turn on the brightness goes very low and I can’t see anything, I tried to raise the brightness level but nothing changes. I made a video that I think explains better my problem
https://www.youtube.com/watch?v=W_n96rVc...
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Risposta più utile
The backlight is not working. Try reseating the connector, and if that does not work, the third-party display may be the culprit. Try another replacement display in that instance, and the dealer of your old unit should refund you for the faulty part.
Punteggio 1
Aggiungi la tua risposta
Ionut Robert Cojocaru sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 0
Ultimi 7 giorni: 6
Ultimi 30 giorni: 18
Tutti i Tempi: 824
