Salta al contenuto principale
Il Huawei Watch GT 2 è la seconda versione della linea di smartwatch GT di Huawei. È stato annunciato a settembre 2019 e rilasciato a ottobre 2019.
How to replacement battery
how many steps and it is hard?
Questa è una buona domanda?
Punteggio 2
Aggiungi un commento
3 Risposte
Apologies as that was the guide for the incorrect device, and it appears as the other commenter said, the battery in this watch is much harder and much much more complicated to replace. I can’t even seem to find any videos online after a long 10 minutes of searching.
Punteggio 0
2 Commenti:
GT2 same watch 2?! Evry one has different Design?!
da
No, they are not the same watch. The battery in the GT2 is soldered on.
da
sadeq lasher  |This video will at least get you to the battery. From there you should be able to desolder it and replace it.
Punteggio 0
2 Commenti:
Your link leads back to here
da
@omeggga let me fix that when I get off work. Thanks for letting me know
da
The battery cannot be replaced on this watch, the connections are SOLDERED!!
Punteggio 0
Aggiungi la tua risposta
sadeq lasher sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 13
Ultimi 7 giorni: 36
Ultimi 30 giorni: 76
Tutti i Tempi: 2,883
