Why is my tablet not charging?
So whenever I put it to charge it says that it is charging but the percentage doesn’t increase
Questa è una buona domanda?
Hi @theguy3842 ,
Have you tried a different compatible charger or tried connecting the tablet to computer and checked if it showed that it was charging OK, you didn’t say?
Use a strong light and a magnifying glass to visually inspect the tablet’s charge port to make sure that there isn’t any lint or other obstruction in the port enclosure that may be preventing a good electrical connection. Also make sure that all the pins are there and that they’re not broken or bent. If there is any debris in the port enclosure, do not use a metal pin or probe to try and get it out. Use a vacuum cleaner and try to suck it out instead
Does the tablet work OK when on the battery only?
If the tablet doesn’t start when on the battery only or it shuts down too soon afterwards then perhaps the battery is failing and needs to be replaced.
Here’s the ifixit Sostituzione Batteria (tipo A) Samsung Galaxy Tab guide, that may help.
Replacement batteries are available online. Just search for ET-BT355ABA to get results for suppliers that suit you best.
Ultime 24 Ore: 0
Ultimi 7 Giorni: 7
Ultimi 30 Giorni: 14
Tutti i Tempi: 888
