Salta al contenuto principale
Rilasciato nel 1989 da Apple Computer, fuori produzione dal 1991
Computer not booting after recap
I bought a Macintosh SE 1/20. It booted correctly from HDD but showed first signs of corrosion on the logic board. I recapped it and reassembled. Now it gives the boot chime followed by a happy mac. Then it starts reading from the HDD. Seconds later it gives a sad mac with error code:
0000000F
00000063
Can anyone give me a hint where to look?
Best,
Markus
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Did you replace the PRAM battery? Also check the socket sometimes the contacts are dirty.
You may need the 3.5” disks that came with the system to run the diagnostics.
Punteggio 0
2 Commenti:
Hi @danj,
Thanks for the reply. I did replace the PRAM battery. Checked with a system disk and I’m able to boot from a system 7.0.1 floppy.
Guess it’s a problem with the system on the HDD. Going to reinstall and check again.
da
@mafo - Yep! Needs a new drive ;-{
da
Aggiungi la tua risposta
Markus Forster sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 0
Ultimi 7 giorni: 4
Ultimi 30 giorni: 19
Tutti i Tempi: 433
