Salta al contenuto principale
Modelli : - multipractic - multipractic plus - K3000 - K3050
The central spindle is split.
I managed to split the central axel due to a very hard piece of cheese. The split has spread out so the tools won’t go on. I have another machine to replace it, but I was cheated as this doesn’t work either. But it can be used for spares. Is there anything you can advice me on, or help me get this repaired somehow? I am in Manchester M9.
Questa è una buona domanda?
Punteggio 1
1 Commento
Hi there, did you manage to get this fixed? I ask as I have the same machine.
da
Aggiungi un commento
2 Risposte
Risposta più utile
This guide helps to fix the issue.
Punteggio 1
Auch bei mir ist die Mittelachse gerissen. Gibt es eine Mail-Adresse oder einen Account auf Telegram, Signal oder auch WhatsApp, damit ich Fotos dazu zeigen kann? Danke vom Zorn
Punteggio 0
Aggiungi la tua risposta
Janis Dolan sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 1
Ultimi 7 giorni: 12
Ultimi 30 giorni: 36
Tutti i Tempi: 558
