Salta al contenuto principale
Repair guides and support for Panasonic's Viera line of televisions.
417 Domande Visualizza tutte
Can I use a power supply from a different model
I have a Panasonic TX-L37V20B and some of the capacitors have gone on the power supply, I’ve been looking the same tv online or ones that has a cracked screen and up for spare and repairs so I can nick the power supply from that but I can only find TVs that are slightly different models, are the power supply’s the same in different models the same?
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Soluzione Prescelta
Hi @peekie ,
Have you tried searching for the power board’s board number (when searching include all info from the board only e.g. board number + Rev number if applicable) to find a replacement board and not the TV model number?
You may get both doing it this way i.e. replacement boards and also perhaps other TV models where the board is used, which you can then look up
It may be easier and cheaper to simply replace the faulty capacitors.
Punteggio 1
Aggiungi la tua risposta
Thomas sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 13
Tutti i Tempi: 95
