Salta al contenuto principale
Windows 10 è una versione principale del sistema operativo Windows. È stata rilasciata nel 2015.
Why can't I install Windows 10?
I am trying to install Windows 10 via USB. I have formatted the USB, however, it doesn’t show up as UEFI. I have looked through BIOS and can’t find any way to change it. Additionally, sometimes when I reboot BIOS, i’ll receive the “Reboot and select proper boot device” message. Any help?
Specs:
MSI B450 Tomahawk Max
AMD Ryzen 5 3600
MSI 1070ti Aero
WD Blue 3D Nano SATA SSD M.2 2280
Corsair Vengeance DDR4 3600MHz
Corsair CX 550M
Questa è una buona domanda?
Punteggio 0
1 Commento
This question was migrated from https://meta.ifixit.com/Answers.
da
Aggiungi un commento
1 Risposta
Soluzione prescelta
How are you writing the USB stick? If you’re using the Media Creation Tool, it writes it with a preference for UEFI boot modes on compatible systems. With these systems, you often need to have it set to UEFI boot for it to show as a boot option. In addition, you’re committing to keeping it as a “UEFI” system once you reinstall since changing back isn’t going to happen without a reinstall.
If you want to have some flexibility, you’ll need to use Rufus.
Punteggio 1
Aggiungi la tua risposta
Justin Shifflett sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 0
Ultimi 7 giorni: 2
Ultimi 30 giorni: 5
Tutti i Tempi: 399
