Salta al contenuto principale
Il Bose SoundLink III, rilasciato a febbraio 2014, è la terza generazione di altoparlanti portatili SoundLink Mobile di Bose. Si tratta di un altoparlante portatile Bluetooth dal design moderno e minimalista.
Bose speaker not charging
My bose portable speaker is not starting after its battery reduced last night.
I hv tried changing cables also(Type C) still its not starting.
please suggest
Questa è una buona domanda?
Punteggio 1
1 Commento
I've got a powercolor 2. The battery ran completely out, and now it will not take a charge or turn on (no lights turn on).
If I plug it into the computer, the computer will detect it and "set it up", however, when I try to run the Bose updater, it fails because the speakers won't communicate with the computer.
There is a popular solution if you search for it - keeping the power button pressed while plugging it into a computer and then unplugging it and letting go, then plugging it back in and pressing the power again, but this does not work for me.
I used them recently and they worked for a number of hours without a charge, so I think the battery is fine, and a quick search online shows this is not an uncommon problem for these speakers. Just want to know what to try next.
Thank you in advance!
da
Aggiungi un commento
1 Risposta
Soluzione prescelta
hariom gangwar  not quite sure what you mean by this “battery reduced “ but I’ll assume you mean the battery went down and did not longer work. Since you already tried a different cable I suggest that you change the battery. IF nothing else it will provide you with a known-well starting point for further troubleshooting. Let us know which Bose speaker this is so we can try and help you further if needed.
Punteggio 1
6 Commenti:
It is recently released bose portable speaker bought 1 months back.
Its battery was low last to last night approx 1-2 % and we left it for changing at night.next day onwards its not starting
da
@hariom gangwar since this is only 1 month old, return it and have them fix it under warranty. After all, you paid for that.
da
Mine is out of warranty. It’s not been charged for a couple years due to moving. What do I do?
da
It is a Bose sound link Bluetooth speaker ||| or 3
da
I’ve had it on the charger for over an hour I still have no light coming on. I understand it needs to be charged extensively but if you could tell me how long before I might see a power light emerge?
da
Mostra 1 altri commenti
Aggiungi la tua risposta
hariom gangwar sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 4
Ultimi 7 giorni: 18
Ultimi 30 giorni: 43
Tutti i Tempi: 3,068
