Salta al contenuto principale
Dopo una pausa di due anni, il modello Sportage è tornato nel 2005, condividendo la piattaforma basata sulla Elantra con la Hyundai Tucson del 2005.
ABS, traction control issue
Hello, a month ago my ABS and traction control and ESC light came on. It went off after a few days. Now its back on. Went off for a day, went back off for a day then went back off. What is the issue?
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
if its intermittent have you checked your battery, if the voltage gets low a lot of cars will shut these systems off the keep the engine running. other than that I would look towards faults with electrical parts of the braking system as they’ll be wired into each other, start with simple things like brake light fuses are firmly pressed in and secure.
Punteggio 0
Aggiungi la tua risposta
Savannah sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 0
Ultimi 7 giorni: 3
Ultimi 30 giorni: 12
Tutti i Tempi: 601
