Salta al contenuto principale
The Inspiron 15-3521 has an optional touch screen feature and has a 15.6" display. This laptop is also complete with a matte finish and keyboard complete with number pad.
40 Domande Visualizza tutte
My laptop is like died
from like week ago its like for many time i have to turn it on its not work then its turn on
when i try to turn on i hear the processor and fan working then its turn off
and try again to finally working
then after that he never turn on ever
can i know where is the damage ?
and thx ?
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
2 Risposte
Soluzione Prescelta
First thing I would do on a “no boot” with fan issues is check the RAM - see if there’s an issue with how it’s seated, or potentially a bad module or two. If you have 2 modules, take 1 out at a time and see if you can get it to boot - if so, that module is bad. At that point, your best option would be to buy a matched set of RAM and replace both of the original modules to avoid any future compatibility issues, if you’ve confirmed there are no other issues. Follow this guide to access the RAM.
If the issue persists, try and boot the computer without the hard drive. Some of these consumer machines (including Dell) are temperamental about booting with a failing/failed HD installed. Refer to this guide to remove the hard drive. I’ve never had an issue with the business Dells booting with degraded drives, but they tend to make the BIOSes more resilient to bad hard drives/RAM on the business computers, and least to the point it can push an alert and then beyond that it's still anyone's guess. It’s not unheard of, so don’t ignore the possibility - especially consumer systems!
The point of the alert the user POST survivability is let's say the SSD is failing in my E6440. I have it set up to warn me if there are any SMART errors, and then give me an alert. It will let me ignore it but what may happen is if I wait too long it may not boot anymore or show up if it fails outright. It is an early warning mechanism - not an override. Think of it as a heads up to backup the system, and stop using it if possible.
If both fail, try removing the CMOS battery for 1 minute and hope for the best. If the issue persists beyond these two things, it tends to be a bad motherboard and that will total the laptop out. However, sometimes you get lucky and removing the wireless card helps.
Immagine Dell Inspiron 15-3521 RAM
Guida
Dell Inspiron 15-3521 RAM Replacement
Difficoltà:
Facile
5 - 10 minutes
Immagine Dell Inspiron 15-3521 Wireless Card
Guida
Dell Inspiron 15-3521 Wireless Card Replacement
Difficoltà:
Moderato
15 - 30 minutes
Immagine Dell Inspiron 15-3521 Hard Drive
Guida
Dell Inspiron 15-3521 Hard Drive Replacement
Difficoltà:
Moderato
10 - 20 minutes
Punteggio 4
1 Commento:
thank you
its very helpful ?
da
Hi! This sound like the CMOS battery is dead.
1) Check if the battery it is a model 2032 (it is the size of a 5 cent coin attached to motherboard)
you can buy it at any farmacy or department store and change for a new one.
2) Other cause is the computer It's overheating and shuts down to protect itself. Check in the fan vent area
smell like something is burn or hot. If this happens the fan and heat sink need to be cleaned.
Punteggio 0
Aggiungi la tua risposta
mz 6s sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 5
Ultimi 30 Giorni: 10
Tutti i Tempi: 215
