Salta al contenuto principale
Dell Inspiron 15-3521 RAM Replacement
Cosa ti serve
  1. Dell Inspiron 15-3521 RAM Replacement, Remove the battery: passo 1, immagine 1 di 3 Dell Inspiron 15-3521 RAM Replacement, Remove the battery: passo 1, immagine 2 di 3 Dell Inspiron 15-3521 RAM Replacement, Remove the battery: passo 1, immagine 3 di 3
    • We are removing the battery to avoid the possibility of an electrical discharge when working with this system.
    • Flip the laptop over.
    • Slide the latches toward the outside of the laptop to unlock the battery.
    • Lift the battery out of the laptop.
  2. Dell Inspiron 15-3521 RAM Replacement, Remove access door: passo 2, immagine 1 di 3 Dell Inspiron 15-3521 RAM Replacement, Remove access door: passo 2, immagine 2 di 3 Dell Inspiron 15-3521 RAM Replacement, Remove access door: passo 2, immagine 3 di 3
    • Loosen the two screws attaching the access door to the laptop body
    • Using a spudger, pry open the access door from the laptop
    • Using your fingers, open and remove the access door from the laptop, exposing the memory cards underneath.
  3. Dell Inspiron 15-3521 RAM Replacement, Memory Card Removal/Replacement: passo 3, immagine 1 di 3 Dell Inspiron 15-3521 RAM Replacement, Memory Card Removal/Replacement: passo 3, immagine 2 di 3 Dell Inspiron 15-3521 RAM Replacement, Memory Card Removal/Replacement: passo 3, immagine 3 di 3
    • To access the memory cards, push out the latches on the left and right of the memory cards
    • To remove the memory card, pull it out of the tray with the latches still stretched out
    • Insert a new memory card in to the memory card tray, depressing until side latches engage with a click.
Conclusione
Altre 7 persone hanno completato questa guida.
Andrew Dippre
Membro da: 10/13/14
2.902 Reputazione
7 Guide realizzate
Clemson, Team 3-1, Benson Fall 2014 Membro di Clemson, Team 3-1, Benson Fall 2014
CLEM-BENSON-F14S3G1
4 Membri
9 Guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 26
Tutti i Tempi: 6,444
