Salta al contenuto principale
Dell Inspiron 15-3521 Hard Drive Replacement
Cosa ti serve
  1. Dell Inspiron 15-3521 Hard Drive Replacement, Removing the Battery: passo 1, immagine 1 di 3 Dell Inspiron 15-3521 Hard Drive Replacement, Removing the Battery: passo 1, immagine 2 di 3 Dell Inspiron 15-3521 Hard Drive Replacement, Removing the Battery: passo 1, immagine 3 di 3
    • We are removing the battery to avoid the possibility of an electrical discharge when working with this system.
    • Flip the laptop over.
    • Slide the latches toward the outside of the laptop to unlock the battery.
    • Lift the battery out of the laptop.
  2. Dell Inspiron 15-3521 Hard Drive Replacement, Removing the Access Panel: passo 2, immagine 1 di 3 Dell Inspiron 15-3521 Hard Drive Replacement, Removing the Access Panel: passo 2, immagine 2 di 3 Dell Inspiron 15-3521 Hard Drive Replacement, Removing the Access Panel: passo 2, immagine 3 di 3
    • Loosen the two screws attaching the access door to the laptop body.
    • Using a spudger, pry open the access door from the laptop.
    • Using your fingers, open and remove the access door from the laptop, exposing the memory cards underneath.
  3. Dell Inspiron 15-3521 Hard Drive Replacement, Remove the Hard Drive: passo 3, immagine 1 di 3 Dell Inspiron 15-3521 Hard Drive Replacement, Remove the Hard Drive: passo 3, immagine 2 di 3 Dell Inspiron 15-3521 Hard Drive Replacement, Remove the Hard Drive: passo 3, immagine 3 di 3
    • Locate the two hard drive screws, located on the left-hand side of the hard drive casing.
    • Loosen and remove these screws using a phillips head screw driver PH0.
    • Push the hard drive to the left, and then lift out of the laptop casing to remove from laptop.
  4. Dell Inspiron 15-3521 Hard Drive Replacement, Accessing Hard Drive: passo 4, immagine 1 di 3 Dell Inspiron 15-3521 Hard Drive Replacement, Accessing Hard Drive: passo 4, immagine 2 di 3 Dell Inspiron 15-3521 Hard Drive Replacement, Accessing Hard Drive: passo 4, immagine 3 di 3
    • Identify the Hard Drive caddy screws, one on each side of the hard drive casing.
    • Remove these screws using a phillips head PH0 screwdriver.
    • Now, with a new hard drive, attach the caddy/casing using the same screws removed from the old hard drive.
Conclusione
Altre 28 persone hanno completato questa guida.
Andrew Dippre
Membro da: 10/13/14
2.902 Reputazione
7 Guide realizzate
Clemson, Team 3-1, Benson Fall 2014 Membro di Clemson, Team 3-1, Benson Fall 2014
CLEM-BENSON-F14S3G1
4 Membri
9 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 3
Ultimi 7 Giorni: 15
Ultimi 30 Giorni: 56
Tutti i Tempi: 32,967
