Issue with Dell XPS replacement battery
I just purchased a replacement battery for a DELL XPS 13 9360.
With the previous battery, the laptop would die as soon as the power cord was unplugged and it always had a yellow flashing light.
Dell BIOS system tests indicated a bad battery.
With the battery replacement, the indicator light no longer flashes yellow continuously and the BIOS tests pass. The battery will not charge past 46% and the laptop still dies immediately if power cord is unplugged.
Questa è una buona domanda?
7 Commenti
Hi @siliconpaladin ,
Couple of things to try just to eliminate them.
Check the output voltage from the charger to make sure that it is 19.5V DC
Create a Win10 battery report to check the status of the battery
da jayeff
Hi @jayeff
Sorry it took me so long to respond. Holidays and several things got in the way.
Confirmed the charger is 19.5V DC (it's the original charger purchased with the laptop from Dell).
Battery report can be found here: https://drive.google.com/file/d/1GMZcnBB...
da Christopher Gardner
@siliconpaladin
According to the battery report the design capacity of the battery is 59994 mWH (59.994Watt Hours)and the full charge capacity is 60002mWH (60.002 Watt Hours) so essentially the battery is fully charged but the system says that it isn't and also it should be able to handle the load without the laptop shutting down.
It could still be a faulty battery even though it shows fully charged it actually isn't and fails when on load
Check that the latest Dell Power management Service drivers ver.3.7.0 A00 are installed. Select Category > Systems Management to find them
da jayeff
@jayeff
Dell drivers installed. It reports excellent battery health but says it's only charged to 35% (which Windows agrees with).
Unplugging the laptop still immediately kills the power.
@siliconpaladin
You may have to install another battery (have you still got the old one?) to prove the problem either in the battery or in the laptop as the software monitoring the battery is at odds with how the battery is behaving i.e. can't power the laptop
da jayeff
Mostra altri 2 commenti
