Salta al contenuto principale
iPad Air Wi-Fi + Cellular, numero modello A1475. Disponibile in grigio siderale o argento, con configurazioni da 16/32/64/128 GB.
PMIC Replaced - Missing voltages
I have an iPad Air (1st gen) which I have replaced the PMIC. The reason for that is because the iPad charges only when it was switched off.
I have lifted the following pads during removal of the PMIC:
  • B17
  • B16
  • B15
  • C16
Dont know If this is the cause of the problems below:
  • No backlight (filters are good)
  • Missing voltage on PP3V0_SPARE1
  • Missing voltage on PP3V0_S2R_SENSOR
  • Missing voltage on PP3V3_ACC
  • No Heat on the board, and I can see apple logo on screen without backlight looping.
Anyone can point me in the right direction or explaining those missing voltage lines could be a BIG help understanding the situation.
Immagine
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
hello Peter,
too high temp and flow you use for taking off a glue and a ic. It seems like cpu overheated. Have you stencil for reballing?
Punteggio 0
6 Commenti:
Yes! I have used a brand new PMIC already reballed.
Also I have measured around all Caps with Multimeter Diod mode wich resulted NO short on the board.
da
Or you suggest I should reball the CPU???
da
this is dependent to board measurement. But it looks like. I would measure RAM and NAND beforehand but it looks like yes, I would do a CPU reballing.
da
sometimes, problem is in technical's hand work. Are you sure IC is sitting down correctly?
da
A smudged the corners and it seems ok....
da
Mostra 1 altri commenti
Aggiungi la tua risposta
Peter Hupuczi sarĂ  eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 4
Ultimi 7 giorni: 8
Ultimi 30 giorni: 29
Tutti i Tempi: 913
