Salta al contenuto principale
Lo smartphone Android Sony Xperia Z5 è stato rilasciato nell'ottobre 2015. Il Sony Xperia Z5 presenta un display da 5,2 pollici con risoluzione 1080 x 1920 pixel ed è dotato di un processore Qualcomm Snapdragon 810, 3 GB di RAM e una fotocamera posteriore da 23 MP.
screen became almost black
Hi Everyone,
Suddenly, I noticed that the phone’s screen became very dark. I needed to put the phone near by a bulb light to be able to see what is on the screen as this made the phone increase the light of the screen. At the same time the phone was very hot although it was not charging (not connected to a charger). I tried to reset the phone however, I noticed that the phone is heating more so I opened the phones cover and disconnected the phone’s battery. I waited few minutes until the phone cooled down then I connected the battery. at this point something started to burn inside the phone. some smoke came from under the metal plate where the red arrow is pointing to in the uploaded photo.
Immagine
Immagine
Immagine
Immagine
Immagine
Immagine
I believe there is a burn mark on the back of the removed little cover. It can be seen on the second and third images.
Does anyone know what I need to do to repair the phone?
Thanks in advance
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
M Hassan you will have to remove the EMI shield to properly identify which component has failed. As you can see there are many so unless you remove it, we cannot assist you any further.
Immagine
Update (10/26/2020)
Still trying to find the eplist for this phone. Typical Sony since they no longer have schematics at all. It may take a while. Part s are identified by reference designator
Immagine
Punteggio 0
3 Commenti:
oldturkey03 - I have added more photos. Could you please check my post (question) again?
Thanks
da
Sorry, What do you mean by eplist?
Also could you please tell me how to find the parts that you mentioned on the photo?
Thanks
da
M Hassan partslist for the circuit board. That way we can determine what values the capacitor and coil are supposed to be. A few years ago Sony stopped using schematic in their service manuals etc. so it is hard to come by via the usual sources. Still working on it but it is not going to be a fast fix :-)
da
Aggiungi la tua risposta
M Hassan sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 0
Ultimi 7 giorni: 2
Ultimi 30 giorni: 15
Tutti i Tempi: 435
